Trying to make sense of the rgb values returned by node.fills
  • November 26, 2021
  • 4 replies
  • 3001 views
Parad0x
I’m getting the rgb values in float format when I use :
console.log(node.fills[0].color)
this is the object which is returned :
    r: 0.09583333134651184,
    g: 0.09583333134651184,
    b: 0.09583333134651184,
I’m trying to use the selected node’s hex or rgba color in the plugin’s UI.
But I have no idea how to use these values as this is the first time I’ve seen rgb values which are not “0-255” (I really hope I’m making sense).
Can this be converted in more “traditional” RGB format (each color values ranging between 0-255)? or is there any other way of getting the accurate HEX color of a rectangle node?
  • November 27, 2021
These values are in [0, 1] range. A very simple mathematical operation can turn it into [0, 255] in case you need it.
Parad0x
  • November 27, 2021
Multiplying these values by 255 seems to give accurate RGB values in 0-255 range. I need confirmation if this is the right way to do it thought.
  • November 27, 2021
Yes, this is the right way. The simple mathematical operation I hinted at is exactly that.
Also check out this library GitHub - figma-plugin-helper-functions/figma-plugin-helpers: A collection of useful helper functions to import to your Figma plugin project — you can find lots of useful functions here for working with colors.
  • December 27, 2021
