There is a difference in shadows in elements when i use auto layout
  • September 9, 2021
  • 6 replies
  • 2144 views
Dimash
I use the same properties for the shadow in both cases. But for some reason, when I do auto layout for any element, the shadow becomes darker. What is the problem?
Best answer by tank666
You need to enable “Clip content” for the frame so that the “Spread” shadow property can be edited. Then the shadows of both the rectangle and the frame will be the same.
https://help.figma.com/hc/en-us/articles/360041488473-Apply-shadow-or-blur-effects#h_01EHARE1ZFNWNFYS92CT3EXN00
tank666
  • 4873 replies
  • September 9, 2021
Most likely your frame has a rectangle that also has a shadow. Disable the shadow for one of the objects (either the frame, or the rectangle that is in the frame).
Dimash
  • September 9, 2021
There is no rectangle inside the frame. That’s the problem
tank666
  • 4873 replies
  • September 9, 2021
Could you share a link to the file?
Dimash
  • September 9, 2021
/file/tLW5KomczvnQrSwpTVxSfD/Untitled?node-id=0%3A1
Dimash
  • September 9, 2021
I can’t include full link in my posts, that’s why sent you a link only like this
tank666
  • 4873 replies
  • September 9, 2021
