When selecting a nested component in figma in prototype view, it automatically highlights the same ones over multiple artboard. I’ve had numerous times when i wanted to select just those layers and the “Select all layers…” did not have the right option. Is it already possible because i can’t find anything about this topic.
The highlight in prototype mode is for the smart animate feature.
You could try selecting one of the components and going to Edit → Select all with same instance. If it’s a component within a component you could then try hitting Enter which will select the child(ren) of that component. You could also try a plug-in like Similayer.
Thanks for the quick reply! I use select similar for some cases but just to speed up my workflow it seemed like such i quick win to select the already highlighted components 🙂
Thank you, this has been driving me crazy what it was for. I just want to select the same component across each of my artboards so I can put the same interaction on all of them! Hopefully this is something we will see in the future
I was looking for the same, but I found a workaround trick. I was trying to select all the home buttons in all my bottom nav-bars. I select one and I see the same highlight, but alas we cannot quick select them. I then selected the home icon inside, which is a variant of a component, then select all with same variant, then hit Shift+Enter. Shift+Enter selects the parent layer, so all my home buttons are now selected. 😇
