Paste text into multiple new stickies
  • January 27, 2022
  • 6 replies
  • 10186 views
John_Alton
I wish there were a way to paste text on the clipboard (with line breaks) into multiple sticky notes. Line break = new sticky.
Right now, I have to individually paste each list item or bulleted item into a sticky. Being able to select a list of text, copy it, and somehow generate a bunch of stickies — each one being one item in the list — would be a big time saver.
tank666
  • 4870 replies
  • January 27, 2022
Hi @John_Alton, you can try using “Create Sticky From Text” plugin.
Figma
John_Alton
  • 4 replies
  • January 27, 2022
That’s it! Thank you!
Alice_Packard1
My teammates and I can’t get this plugin to work; any others out there that are more reliable?
tank666
  • 4870 replies
  • February 9, 2022
Unfortunately, I didn’t find another plugin.
I noticed your comment on this plugin’s page, you mention copying spreadsheet data. FigJam supports pasting copied cells from a spreadsheet, which turns each one into a sticky note. That is, you can do without the plugin and use the standard FigJam function. For more information, see the Help Center article:
Figma Help Center
Andrei_Iancu
I’m not sure if this works, writing from mobile, but Automater has the ability to Copy Selection and Paste Text.
If you copy 1 layer, you’ll paste the text from that layer to every text layer from current selection.
If you copy multiple layers, it will paste the text from the layers matching the position (is more natural then i explain here…)
I didn’t test it on Figjam, but it should work. 🤔
  • March 11, 2022
