LAUNCHED: Add the option to set the size of texts in local variables
Show first post
christianhsmartins
I can’t wait, it will help a lot.
Valentin14
Yes please add this. Wanted to restructure a lot of components. But I’m stuck. It would be such a big help.
Clark_Wimberly
Any update here? We are actively holding off from making styles in a few very large projects because we’re assuming variable support in type sizing is going to land any moment now. Can you give us a hint?
Leonid
  • October 23, 2023
October 23 checking in.
  • October 24, 2023
this feature would really be helpful, since it would make the use of a large token-system complete to use for different devices, for now it’s almost useless…
Costas
  • 6 replies
  • October 24, 2023
Same here, we are not using variables in our projects because of this.
Hoby-Van-Hoose
Our design systems are languishing in half states of variable conversion. This is literally the only reason many of our simpler components still have variants.
Somi
  • 5 replies
  • October 27, 2023
Come on Figma - go! 🙂
Chase89
  • 7 replies
  • November 3, 2023
I think that the designer would still need to create text styles and they should be able to call upon those styles in local variables. For example, you may need the same size font, but a different weight, or maybe your mobile view uses a different font but the same size, or if the line height is different, etc. If variables could call on styles, then we could hit multiple points at once for several different use cases.
Clark_Wimberly
I think we’d want it the other way around, where Styles can call on Variables. The “style” should be the collection of variables in use.
But either way would be great! Maybe both directions?
Somi
  • 5 replies
  • December 5, 2023
I’m afraid that we won’t be getting an update this year. What a disappointment 😦
I thought soon would really mean soon …
Daniel_Latsch
Looking forward to v2 🙂
Liam_Owen
  • February 12, 2024
This is also a huge need for me. As much as variables are a step in the right direction, the fact that they can’t be used for all properties of the same type, means that they can’t be used for everything. This can get extremely confusing, because some aspects of a design system are governed by variables, whereas some are controlled by instance swaps, text styles, etc.
Somi
  • 5 replies
  • February 14, 2024
Don’t worry, it’s coming soon …
They call it “typography mode”. The first months in beta mode are free for everyone.
BUT after that you will still be able to set the basic typography settings.
Dominik_Vassilakopoulos
Is there an update on this? It still says here that the whole thing is “coming soon”. When can we expect the release? Reponsive design (with variables) is impossible without it. There probably isn’t an openly communicated timeline anywhere right? It really is a NEED.
Charlie_Pratt
Piling on to this one. We need this, big time. Some transparency would be nice from the product team.
Martijn_de_Visser
Another +1 to keep this topic alive. Please add font properties to local variables.
wllung
  • 14 replies
  • March 28, 2024
+1 for this thread. Typography is probably the most repeated UI element, it’s where variables are most impactful
Maia_Aizner
+1 to keep the topic alive. I ended up here trying to solve this -
Universalnick
  • 12 replies
  • July 2, 2024
@dvaliao This topic can be marked as “Launched”
  • 4751 replies
  • July 2, 2024
  • September 30, 2024
