Interactions using variables
Ninjanim
"Hi,
The link below is a link to a Figma ConFig 2023.
At 34:12, Miggi is demonstrating how to create interactions using variables.
I have 2 questions.
  1. Why did he use the string-type variable ‘load_percent,’ and how was he able to assign its value to the number-type variable ‘load_value’?
  2. How can we ensure that the rectangle grows to fill the width exactly when the percentage reaches 100%?"
Any help would be greatly appreciated, thanks. 🤓
Best answer by Haroll
Hello @Ninjanim
Why did he use the string-type variable ‘load_percent,’ …
Pretty sure this variable is assigned to the text displaying the progress in the progress-bar
You can convert a number to a string (but not a string to a number) by adding something between double quotes to the value of the number variable (as shown below). I made an example since it’s not visible through Miggi’s demonstration.
Once again, it’s not visible through Miggi’s demonstration, so I’ll assumed he hard coded the value and made the math.
You can do the math too, having a variable defining the total width (e.g: #total-width) of the container and then it’s a simple percentage calcul :
Set #total-width to #total-width / 100 * #load_value
Let me know if it helped!
Haroll
  • Active Member
  • July 25, 2023
Hello @Ninjanim
Ninjanim
Thanks for the help and the reply.
It worked somehow, I had to find out 3.3 by trial and error. I hope I get better with more practice. Thanks.
Stefan_B
I wonder wheter it is possible to use variables to hide and show other components, like:
is it possible to use on click to change another element?
Ninjanim
This is how I would do it.
Step 1: Create local variables.
Step 2: Assign variables to appropriate layers(sometimes, you need to do right mouse click or detach instance to see the honeycomb symbol to assign variables).
Step 3: Apply interactions.
  • September 3, 2023
