Importing svgs with masks broken
Noah_Seltzer
When importing the svg document at the bottom of the page(taken from <mask> - SVG: Scalable Vector Graphics | MDN), the resulting figma document does not preserve the masked elements.
imported into figma
rendered in webpage
Is there something I can do to get around this? Maybe a different method of importing the masks?
<!-- Everything under a black pixel will be invisible -->
<path d="M10,35 A20,20,0,0,1,50,35 A20,20,0,0,1,90,35 Q90,65,50,95 Q10,65,10,35 Z" fill="black" />
Best answer by Gleb
This is a known limitation. Use this plugin: https://figma.fun/W17tMs
Figma
  • 4710 replies
  • May 27, 2021
Figma
Noah_Seltzer
thanks @Gleb I really appreciate the response
Morten_Vallentin
Still no solution for this? We use a lot of illustrations built in illustrator with transparency masked layers and this is becoming an issue, since all masked layers are unmasked when placed in Figma… pretty uncool, Figma…
Adria_Cruz
HI there Figma! Any updates on this? Building a library of broken illustrations atm… 😦
TEAM23_Design
Any updates? Supporting all SVGs from Illustrator is fundamentally important to us.
Dustin_Coffey
Still no fix? Please give a workaround.
Nelly_Ragua_Miranda
Hi, Figma! any updates ?
Kristoff_Bogaerts
This really should be fixed asap!
Lillian_Wyse
I soooo need a workaround for this it’s screwing up my workflow
Mohammad_Amin_Zamani
hey there… you have no plan to solve this?
Luke_A
  • June 29, 2022
Figma, seriously. A vector based software that won’t export vectors properly.Please solve it ASAP. We spent day trying to find a work around.
  • 4710 replies
  • June 30, 2022
Here is the plugin that fixes the issue: https://figma.fun/W17tMs
Figma
Luke_A
  • June 30, 2022
Hi, Gleb
This fix illustrator to Figma imports.
The problem here is Figma export engine/coding of SVGs, no matter how good imported SVGs are, once in Figma and exported from it, they break.
Tried to export the same SVGs from sketch of AI, no problem. It’s Figma way of exporting.
It also does the same if we use Zeplin, as we tried that to, once exported to Zeplin if the SVGs are downloaded from there, they’re broken. Same ones exported to Zeplin from sketch are fine.
It’s Figma export. Unfortunately.
The team works at one of the major creative agency and will have to use another tool for our handover to developers, once it comes to these illustrations.
We tried all sort of solutions, also following other threads here with fixes the community suggested; removed strokes, masks, flatten shapes, remove bleeding, making them pixel perfect (all of which water time), with no luck.
  • 4710 replies
  • July 2, 2022
Ah, you are talking about export. This thread is about import. Feel free to send a bug report to Figma about export with specific examples and what exactly is broken because from your message I can only see that something is broken but not the slightest idea as to what. Here is the bug report form.
Lee_Robertson1
This didnt fix it for me 😕
and im importing from AI to Figma
It still didn’t fixed second the plugin above is no more supported.
I have facing the problem of exporting my svg that has mask on it. When i import it in rive it brokes:
Rogie_King
  • Designer Advocate
  • 12 replies
  • March 14, 2024
Curious, is this a Rive or a Figma issue? Can you send over the file and/or SVG?
Here is the link of my project:
Figma – 24 Jul 23
