I can't update the plugin anymore
  • October 4, 2022
  • 9 replies
  • 1013 views
Andrei_Patriciu
I was able to update the plugin in the past but recently it is not possible.
The plugin id is 1024395026904248839
and it is not disconnected from the manifest version.
After I select [publish] plugin and I select the appropriate item, the button [next] gets activated , I click on that and nothing happen.
Best answer by tank666
Ok, if this is the same account that you first published the plugin from, then you should see the “Publish new release” option, as in the screenshot below.
dev-publish-update
If instead you see the item “Publish”, then you are probably signed in to the wrong account or something else.
You can try the following:
tank666
  • 4870 replies
  • October 4, 2022
Are you trying to update the plugin from the same account that first published it?
Andrei_Patriciu
Yes, I am using the original account.
tank666
  • 4870 replies
  • October 4, 2022
dev-publish-update
Andrei_Patriciu
This is what I see
I can, surprisingly, unpublish the thing but not publish updates 😦
There is a team account I have used to list the plugin on the market but under tht or this I have the same experience.
Thank you.
tank666
  • 4870 replies
  • October 4, 2022
Try re-importing manifest.json.
Andrei_Patriciu
I did. This thing opens:
Andrei_Patriciu
Thanks @tank666, It worked finally after importing the manifest from that particular place in the account/plugins view. Importing from manifest in other place in the app, like the contextual menu, is not working.
Thank you!
tank666
  • 4870 replies
  • October 4, 2022
You need to click not “Run”, but “More options” ( next).
  • November 3, 2022
This topic was automatically closed after 30 days. New replies are no longer allowed.
