How to see original instance of component from left Assets Panel?
  • May 17, 2021
  • 1970 views
David_Bruggink
I’ve been unable to find sufficient guidance for interacting with the left Assets panel. I’m trying to go to an original instance of an asset from the left Assets panel. Sometimes left-clicking will highlight the object; sometimes it will force you to drag an instance of a component to the page (which you can’t Esc out of). If I right click, it only causes the “Remove from library” contextual tooltip to appear, which I don’t want to do. How can I just click it and go directly to the original context of the component? Or can someone provide me with guidelines for how clicking will reliably interact with components in this panel?
Pat3
  • May 11, 2022
This is a problem for me as well. The only solution I’ve found is in the layers panel, you can identify which elements are master components and which are instances by the icon. Master components use a 4 diamond icon and instances use a single diamond icon.
