How to resize components as an nested instance with a base component?
Jelle
Hello,
I’m having issues with building my components.
The idea is to have a base component where I can edit the styling. Then I work with nested instances and make variants of them.
However, when using this component across design files I can’t figure out how to make sure the frame resizing works correctly when changing the amount of text lines for example (see screenshot).
Is this even possible to have the frame grow evenly with the base component frame? Or is there another work around.
Thanks so much! Enjoying every second in Figma 🙂
Sebastian_Hall
I am not 100% sure I fully get what you mean, as in the frame growing by using auto layout? play around with that would make things resize after content.
alternatively when you mean that you have resized content but the frame stays the same as in your screenshot
What you could do then is: when you’ve selected it, in the frame part on the right-hand side, press the four arrows in the top right
hope this helps!
Jelle
  • May 25, 2021
Hi Sebastian, Thanks for your quick comment.
I mean that the component is working as it should, only the frame doesn’t take the correct size (as shown in the screenshot) therefore it would be hard for other designers to mark the right margins.
The issue seems to be in the fact that I use a base component (.base/notification) and then nest the component (Notification banner) in it.
I created a Figma file that gives a better demo of the problem I’m facing. I need some assistant here 🙂
Figma – 25 May 21
alexf
  • 27 replies
  • May 25, 2021
Hi @Jelle,
You need to make the Notification 2 components take advantage of auto-layout. Then these will resize as expected.
Cheers,
Alex
Phil_Larsen
  • Active Member
  • 130 replies
  • May 25, 2021
You’ll also want to ensure that you’re using auto-height on the text layer itself. Attached a screenshot with the proper selection on the Resizing attribute of the text layer.
Gerrit
  • March 23, 2022
On Mac use CMD + Click + Drag on the side of the component you would like to extend. This will make the component the size you desire. (Assume you would replace Command with Control on Windows)
Ahmet_Ertunc
Thank you, it works… but i wonder that why I can’t change the size of component just by click + drag? Why should i press CTRL?
Yiset_Casanella
Hi Gerrit, I’m on Mac usingCMD + Click + Drag on the side of the component I want to extend but it makes the elements inside of it bigger as well. I need to expand the component frame without the elements inside of it getting bigger. Do you know how I can do this?
Gerrit
  • November 9, 2022
Hi Yiset, you can try playing with auto layout while setting fixed withs for your components.
