Help needed: Adding Text to createShapeWithText 🛠️
Rob37
Hello Friends of Figma!
I’m building a Figjam plugin which generates shapes with dynamic text content, and I need your expertise to make it perfect!
I’m using the figma.createShapeWithText() function, which creates a nice shape just as expected. However, when it comes to adding text, I’m a bit stuck. I want to pass the randomText variable into the “characters” property, but no luck so far. 😕
Has anyone here cracked the code for a similar situation? Your valuable insights would mean a lot to me!
Here’s what I’ve done so far:
async function createRandomTextShape() {
  const x = 100;
  const y = 100;
  const randomText = "Aliqua consequat elit ipsum.";
  const shapeWithText = figma.createShapeWithText();
  shapeWithText.shapeType = "ROUNDED_RECTANGLE";
  shapeWithText.x = x;
  shapeWithText.y = y;
  shapeWithText.fontSize = 12;
  shapeWithText.textAlignHorizontal = "CENTER";
  **shapeWithText.text.characters = randomText;**
  figma.currentPage.appendChild(shapeWithText);
Massive thanks
tank666
  • 4873 replies
  • April 12, 2023
Before changing text properties, you need to load the font.
figma.com
Also you should change these lines:
to
shapeWithText.text.fontSize = 12;
shapeWithText.text.textAlignHorizontal = "CENTER";
Rob37
  • April 14, 2023
Thanks a lot Yury! I managed to do it 😉
As you said I had to load the font before calling figma.createShapeWithText();
  • May 14, 2023
