Has anyone figured out a way to hack auto layout so that a frame is constrained to the parent, while everything else adheres to auto-layout?
Charlie_Wu
This is a niche problem but I’ll describe it in detail below.
Normally, if I apply a solid background and shadow to a frame and added auto-layout, this would be fine, and I wouldn’t have a problem. However, in Figma, when a transparent layer has a shadow, the shadow appears beneath the transparent background (it does not do this in HTML/CSS).
In order to work around the shadow affecting the background, I created a “layer” component that contains the shadow with a mask that removes the shadow from the contents. You might be able to see where I’m going with this.
I want to apply this style to a parent frame with auto-layout. My current solution is to put this layer component inside a zero-height frame, which is then inserted inside the parent auto-layout container. Whenever the parent container changes sizes, I need to manually adjust the layer component to match the size of the parent.
Is there a way to make this layer component constrained to the parent auto-layout style without me having to resize it every time?
See demo here
Best answer by tank666
For your hack to work, you need to do it on each side separately. I edited your example:
Figma – 1 Jul 21
Charlie_Wu
  • July 1, 2021
As a note, if the shadow effect ignored the frame background, this wouldn’t be a problem at all.
tank666
  • 4858 replies
  • July 1, 2021
Figma – 1 Jul 21
Charlie_Wu
  • July 1, 2021
Very clever, good solution. Thanks Yury!
  • July 31, 2021
