Figma Freezing When i Try to Edit 1 Color In 'Tamagui' Design System
Hi,
Hope you can help, FIgma is freezing every time i try to update a singhle color token in a large design system.
Im just trying to change the values in the Theme / Color / Blue 12.
I really want to use this design system - i hope you can help.
I also tried to delete ‘Blue 12’ color from the theme but it crashes every time.
Heres the file:
https://www.figma.com/file/zqMZoVth4OjYyxo3WOP3md/Tamagui-v1.2.1-(Duplicate)?type=design&node-id=1180%3A3541&mode=design&t=6ufpyhB0vaV4nauH-1
Many thanks
Best answer by Celine_D
Hey @Kieran_Holden , I see in the backend that the technical quality team replied to you.
Here is the response that may also interested the community (please continue the conversation via email if you have any other questions, your support ticket will open automatically):
The engineers have let me know that this is happening because ‘blue12’ is used in the variable ‘color12’ which is currently used on a extremely large number of components (>17k), which all need to be updated when the variable value changes, thus the delay. The team will try to improve the performance of these kinds of changes in the future, but this is a non-trivial amount of work and will take some time.
For now, I’d suggest removing the variable from the Lucide Icon set, and any other large component sets which are likely to only be used while nested in other components, and checking if this helps.
As some general best practice feedback, we do not recommend storing large amounts of icon components as a single component set, as when you make use of any of these icons in a new file, all of the icons in the set are loaded there and stored on the internal canvas, leading to unnecessary memory use. We instead suggest you use individual components for each icon and Name and organize components to allow for easier swapping of these components.
@Notable and for others in the community, if this workaround below doesn’t help, and you’d need further assistance, please reach out directly our support team with a URL of the file: here
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com as an Editor, so we can take a closer look.
I’ve gone ahead to mark as solved and close the topic here. Thank you!
Celine_D
  • 3418 replies
  • May 10, 2024
Hey @Kieran_Holden , sorry to hear this is happening. This looks buggy!
I see on our backend that the support team is investigating it. Please continue the conversation via email, and feel free to share any updates for the community here.
Notable
  • November 10, 2024
Thanks Caroline I also have experienced the exact same problem when trying to edit “Color 12”
Celine_D
  • 3418 replies
  • November 14, 2024
