Error making a POST request in a create-figma-plugin codebase
  • December 6, 2022
  • 1258 views
neicore
Hello,
I am working on this Figma plugin and I am using create-figma-plugin toolkit. I want to integrate the plugin with LemonSqueezy’s license key API. I am making a post request and it doesn’t work giving this error:
Error: in fetch: Expected "init.body" to have type Uint8Array but got string instead
    at Proxy.fetch (eval at <anonymous> (eval at createScopedEvaluatorFactory (671d607b-e167-4ac8-a492-12b74d724c97:1:6906)), <anonymous>:23:21)
    at doit (PLUGIN_1_SOURCE:114:29)
    at eval (PLUGIN_1_SOURCE:151:7)
    at eval (PLUGIN_1_SOURCE:56:7)
    at invokeEventHandler (PLUGIN_1_SOURCE:62:35)
    at figma.ui.onmessage (PLUGIN_1_SOURCE:73:11)
    at ptr.callFunction (figma_app.min.js.br:717:4755)
    at iframeMessageHandler (figma_app.min.js.br:1440:17341)
    at EIo.toplevelWindowMessageChannel.port2.onmessage (figma_app.min.js.br:1409:5506)
Here is the code:
try {
      const res = await fetch(
        'https://api.lemonsqueezy.com/v1/licenses/activate',
          method: 'POST',
          headers: {
            Accept: 'application/json',
            'Content-Type': 'application/x-www-form-urlencoded',
          body: 'license_key=38b1460a-5104-4067-a91d-77b872934d51&instance_name=Test',
      const data = await res.json()
      console.log(data)
    } catch (error) {
      console.log(error)
The same code works in codesandbox and in a code base using vanilla js.
Any help is appreciated, thanks
Palash
  • December 20, 2022
You might need to convert your “body” to a Unit8Array using TextEncoder
See this stackoverflow answer for an example: javascript - Converting between strings and ArrayBuffers - Stack Overflow
Also, I hope that’s not your actual API key, if it is, you might want to regenerate it😅
neicore
  • 4 replies
  • December 22, 2022
Thanks for the reply, been there it didn’t work. I have since abandoned the feature 😦 And not that’s not my key, it’s from the doc 🙂
  • 4706 replies
  • December 22, 2022
Not sure about create-figma-plugin specifically, but in general I would recommend you do the fetch request inside of the plugin UI instead of plugin backend. The built-in fetch in the plugin backend is not a full-featured replication of the actual fetch. It still has some sandboxed limitations.
