Copy image into instance not working anymore?
  • October 27, 2022
  • 5 replies
  • 435 views
Robert22
Is the option to copy/override an image in an instance removed? Worked before using short coammand “Command + shift + c”, “command + shift + v”
Its way more time consuming changing images using finder
Best answer by tank666
Perhaps you mixed up the shortcut. To copy properties use Cmd+Opt+C.
Robert22
  • October 27, 2022
command + v
tank666
  • 4873 replies
  • October 27, 2022
Robert22
  • October 27, 2022
Thanks a lot! Perhaps I did. Remember it was different before, maybe getting old 🙂
Robert22
  • May 29, 2023
Did they change this again? Because cmd+opt+c will not will not do this anymore
tank666
  • 4873 replies
  • May 29, 2023
Please check the shortcut in the Figma UI and make sure that no other application/extension is intercepting the shortcut.
Figma Help Center
