Export as PDF only text = 3,5 mo?
Hello community,
I looked throught the forum but could not find any solution to this. I started doing my curriculum on Figma and I could notice a problem with the PDF’s weight
I started deleting each elements and re-exporting to see which one is causing the anomaly, and curiously, one single paragraph weights 3,2 mo…
See pictures attached.
1- A solution was to put the Figma-pdf in indesign and export again. Resulting with a 950 ko document which is, again, too big for just text. And too big for Linkedin 😦
2- Fattening the text didn’t change the weight.
  • November 5, 2023
I made it in Indesign and it is 88ko … 🙄
  • 4706 replies
  • November 5, 2023
You can use pdf compression tools
Joris_Placette
Use
  • Export to pdf
  • PDF to docx converter
  • MS Word : back to PDF
Tadam, small fole now.
Will keep perfect layout and formatting.
May break accents or such ï ç, and fonts.
Shrinks things down to a few KB, though.
