How to work with imported component
  • January 24, 2024
  • 9 replies
  • 727 views
Tomas_Bana
Hello,
I need help with my code. I am importing components from the team library. When I call the import function, I get back a JS promise. I don’t know how to work with this promise. I need to change the text and variants of components in this imported component.
My code:
async function importNode() {
let importComponent = await Figma.importComponentByKeyAsync(“5cad1f5ace96bf648”);
const favC = importComponent.findOne(node => node.type == “COMPONENT” && node.name == “Favorite”) as ComponentNode;
return favC;
How can I access the imported component and browse it and use the embedded components?
Thanks
tank666
  • January 24, 2024
Tomas_Bana
  • January 29, 2024
Sorry for my dumb questions, but i don’t know what you mean “variable already stores a ComponentNode”. Maybe I asked the wrong question.
Now I have an instance, but when I try set the property I get a error
let importComponent = await Figma.importComponentByKeyAsync(“5cad03bxxxxx”);
importComponent.createInstance()
importComponent.setProperties({‘Layout’: ‘Mobile’});
Error: Property ‘setProperties’ does not exist on type ‘ComponentNode’.
I don’t need to change only properties. My component includes a more component and Ii need access to all children’s components. And don’t know how 😦
How i get access to the component (name = favorite) which is inside the “ImportComponent” ??
tank666
  • January 29, 2024
figma.com
Find the desired node in the children’s tree.
Tomas_Bana
  • February 12, 2024
Thanks for your advice. I use the function children, and get back the children instance component. But when i trying to change property with .setProperties. But I’m getting an error does not exist on type ‘SceneNode’.
We are a bit confused, I don’t know how to change the text or property for embedded component instances {label} or instance favorite. Attached is an example of the structure of a component
Thanks
tank666
  • February 12, 2024
On which node was the setProperties method called?
Call the setProperties method on the “Participant” instance or change the characters property value of the “{Label}” text node.
// Set a value for a component's text property
pacticipantInstance.setProperties({'textPropertyName#id': 'Something'});
// Or change the value of the characters property
label.characters = 'Something';
Call the above method on the “Favourite” instance.
Tomas_Bana
  • February 13, 2024
this is my code:
let importComponent = await figma.importComponentByKeyAsync("5cad03b3xxx");
importComponent.children[0].setProperties({'State': 'Like'})
tank666
  • February 13, 2024
I don’t know why you use this way, but I would do it like this:
let importComponent = await figma.importComponentByKeyAsync(key);
let instance = importComponent.createInstance();
instance.children[0].setProperties(obj);
Also make sure that children[0] is an instance.
And where do you see the error: in the Figma app console or in the IDE?
Tomas_Bana
  • February 13, 2024
My mistake, I see the error in my IDE. But when I run the plugin in Figma it works.
Thanks.
I have a last thing. When I am using setProperities and choosing from options everything is good. But I don’t no how a set value for properties (set text).
My code:
instance.children[1].children[0].setProperties({‘Time’: ‘11:00’});
I want a set text for properties Time, but my code doesn’t work.
Thx.
tank666
  • February 13, 2024
