Rename variants properties figma in bulk
Andreia_Tenreiro
Hi!
Is there any way to rename variants’ properties in bulk?
For example, I have many variants with the name “Property1=Large” in many different components, and I want to change them at once to “Size=Large.”
Like RenameIt plugin for variants.
Thank you!
Best answer by Pavel_Kiselev
There is a plug-in - Select by Name | Figma Community
It would do the trick for you.
Pavel_Kiselev
Well, you can do it with the basic rename feature. Select layers you need to update, hit Cmd+R and in the top box type property name you want to change
Andreia_Tenreiro
Thank you so much!
How do you select a different variant in different components?
Pavel_Kiselev
  • 438 replies
  • June 21, 2022
Andreia_Tenreiro
Thank you @Pavel_Kiselev 🙏
