Error when updating component and apply to instance in different file
  • October 28, 2021
  • 701 views
Lucy_Binh_Lam
Hi folks,
I got an issue when updating components on a Design System file. After making some modifications, such as changing the font-weight from Regular to Black, then I publish that change. Next, I access the design file and apply that change. I feel frustrated when all the values I input before for those items are reset back to the original component.
For example, the component has Label > Value. And the instance of that component in the design file is Full Name > John Doe. After updating and applying, the instance is reset to Label > Value instead of keeping the input value Full Name > John Doe.
Did I make any mistakes? Please show me how to fix it.
Thank you.
  • November 27, 2021
