Hi all!
I ran into a text component issue. I have a simple cell component which contains another component inside (is wrapper over text with size options)
Everything works fine until I change the text size option of the nested component in the Parent. After that, in all cells that are inherited from the main, the typed text is reset
I’m expecting the text size to change while keeping the text content
To reproduce I created a link: https://www.figma.com/file/cqfyUxYEiPya2ruKh9jEvc/Figma-Nested-Component-Issue?node-id=0%3A1
Thank you!
