Deep select - how to select something that is below an group?
  • August 24, 2022
  • 4 replies
  • 4464 views
SaroGFX
In XD and Sketch, when you Cmd + Click on an item, you go 1 level deeper incrementally. How do you do this in Figma? It works only in a group, and then goes back to the to level.
How the heck do you select a group, that is covered by another group?
An example below: how do you select the photo backdrop in here? Without doing it via the layers panel (which is very time consuming in huge files with many many layers…)
Screenshot 2022-08-24 at 10.10.31
Best answer by marksworld
Hi @SaroGFX
I would use ⌘ Command on Mac or Ctrl on windows + right click on any frame. You should then see a layer menu where you can then select your specific layer.
But here comes another tip: mostly I use Enter and Shift + Enter to navigate between the layers.
  • Enter = select children = from the current selection, highlight all items on the same level below
  • Shift Enter = select parent = from the current selection, highlight all items at the same level above
I hope this helps.
marksworld
  • 5 replies
  • August 24, 2022
Hi @SaroGFX
I hope this helps.
SaroGFX
  • August 24, 2022
Thank you! That helps a little. But i am really wondering how one uses Figma professionally without spending half the day looking at the layers panel. I was hoping I was missing a feature… 😦
Really hope Figma will add this (deep clicking through will go to next group and so on) because it appears to be so essential for a quick workflow.
The keyboard shortcuts don’t really help much because you need both hands. Might as wel click the layers tab then.
Florin_Kis
  • 6 replies
  • March 27, 2023
I recently transitioned from using Adobe XD to Figma, and I had been missing the feature of deep selection. Until now … not as XD but good enough. ♥️
Yejin_Park_Private
I’ve been using Figma 3 years shift+clicking every child layer… what a game changer
