Why is "on tap" not showing up?
Jeffrey_Nevels
I’m not seeing the “on tap” option as an available interaction. Please help.https://www.figma.com/design/KmeDMxmPVcziLtkf3Uz8Dt/Legal-Criminal-Defense?node-id=808-149&t=Cl2vVIJ2o7xIgFkE-1
Nellya
  • 662 replies
  • December 16, 2024
Access to your file is restricted, but on tap interaction is available only if you choose any mobile device in prototype settings. Probably you didn’t.
Jeffrey_Nevels
Nellya
  • 662 replies
  • December 16, 2024
I checked your file, the problem is just like i said — no mobile device is selected.
The width of your mobile frame is 402 px, so you need to select iPhone 16 Pro here
Jeffrey_Nevels
Can you please help me understand why there is no “Content Proptery” option? I have attached a screenshot
Nellya
  • 662 replies
  • December 23, 2024
It’s here in UI3
Jeffrey_Nevels
How do I download UI3? I downloaded the newest Figma update. Was that included?
Nellya
  • 662 replies
  • December 24, 2024
Yes, it included in the newer version. Can you share a screenshot of your interface?
Jeffrey_Nevels
Here.
Nellya
  • 662 replies
  • December 26, 2024
You already use UI3 — the newest version of Figma interface
Jeffrey_Nevels
You claim that I already use UI3. So, please see the attached screenshot and explain why the top version looks different from the bottom version. His version says “create component property” and mine says "create property or variable. Also, he has the options “Name and Value”, while my options are “Create Property, Name, and Value”. However, my value option has a slider, and his value option has a text field where he can type, “Menu button”.
Nellya
  • 662 replies
  • December 30, 2024
Because he use old UI, but you use the new UI. I’m already posted the screenshot, you pressed the wrong button. You need to click button on top. Or just change the UI to old one.
