Why did you separate text layout from typography in new UI???
Allie_Surdovel
Hello, I am wondering why you have separated text “layout” block, (fill width, within container, etc) and moved it above and away from "typography"UI block?? You have placed “appearance” weirdly inbetween the two, which should be moved to be above fill and stroke. This is incredibly inconvenient and has added a great deal of time to my flow, before I was easily able to adjust text all at once and now i have to move back and forth between the two. REALLY HATING THIS. At least allow custom organization of the UI blocks if you are trying to have the Figma layout match illustrator. ALSO WHY HAVE YOU HIDDEN UNION OBJECT IN A KEBAB?? WHY!!! This new ui is making me incredibly slow and is obviously hasn’t been thought through with actual designers in mind. Anyways I am enraged enough to submit this feedback that will never be read, instead of getting the work done that needs to be finished. Hello void…
Be the first to reply!
