Hi guys,
So I have a component which has a few buttons inside of it. In the prototype, I want one of the buttons to change to HOVER in the prototype, so I’m using the While Hovering action. The problem is that in the Change To section, I can’t actually control that button inside the parent component, but the parent component itself, which makes absolutely no sense.
Is there a way to simply control the button inside the parent component?
Hey @SandeepReddy
Thank you so much for taking the time to write this amazing story. Very captivating to say the least
Will give it a try tomorrow and let you know.
Thank you so much again
hey @SandeepReddy
What do you mean the button should be variants of the parent component? I am using the button component I use everywhere, throughout the app, why would I even consider creating a new button for every other component that uses the same button I’m using everywhere? Sometimes I think the Figma UX design team likes to drink on the job…
@Gleb
I tried it, but it’s not what my problem is
So imagine Frame1, where the button is, is actually a component. Which works fine if it doesn doesn’t have variants. But now add a variant to the Frame1 component. When trying to apply the hover effect to the button, you won’t be able to, because, when selecting the CHANGE TO variant, you’re actually gonna see the Frame1 variants, not the button variants.
NOTE: If you add the hover effect to the button BEFORE adding another variant to Frame1, that specific instance will still work. But if you wanna do that again with another instance you won’t be able to.
Can you please share an example file link? I think I understand what you mean but need a specific example.
Not a forum bot, just someone wasting their and others’ time. It’s very easy to spot the way chatgpt speaks, it’s not how a human would speak. Also the response is vaguely on topic but is complete nonsense because gpt doesn’t know the inner workings of Figma especially in a complex scenario like yours.
Hi @Gleb
Sorry for the delay.
I made a quick testing file. Basically, if you preview Frame 1 everything works fine, because the parent component of the button doesn’t have other variants, and in the second example it doesn’t, because it has multiple variants. Teating.fig (28.0 KB)
When importing it doesn’t give me any prototype connections. If it had some when you exported the file, it’s probably a bug.
Usually it’s better to share the file link with view access. It saves time since I don’t have to import it and also saves you from such bugs as .fig is known to be a not reliable format.
Regarding gpt I honestly don’t know.
In any case I’ll try to poke around your file and find the issue.
@Gleb
No, there are no prototype connections, the only interactions are on the button, that’s where my problem lies I made two examples to show how the hover works in one case vs the other.
Long story short, in the second example you can’t apply the hover effect to the button, because the parent fcomponent has 2 variants, and when you apply WHILE HOVERING to the button, from the CHANGE TO you can only change the parent component variants, NOT the button’s variants. Which makes zero sense
