I noticed that the starting frame thingy is not retained in the destination page (the one you paste the content into) - so you have to go in the right side and select it from the drop down or there will be no starting frame. Make sure you click outside the stuff in the page (on the background area) so that setting will appear in that right hand column.
Then also with regard to getting the content into the other page…
I’m not sure if I’m doing it the same as you or not but if I …
Open the prototype tab (source page)
Select everything in the page
Press Ctrl + D (duplicate)
Press Ctrl + X (cut)
Move to page I want to put the contents into
Press Ctrl + V (paste)
That works for me.
Note: I have not tried it with just a portion of a prototype (only the whole thing). Perhaps it would not work if all the links are not selected (ie: some links extending outside the selected part and connecting to other stuff in the page). I don’t really know. But for the entire thing the steps outlined above have been working for me.
Was done in the online Figma (not tried in any desktop app of it)
Here’s a workaround — while in Prototype mode, copy the prototype and paste it into a brand new or different file. Then copy it again while in the new file and paste back into a different page in the original file. All your interactions will be preserved.
yes, this hack works indeed, and for the sake of having a bunch of frames pasted weirdly on top of others, I group them before moving into another page, so it’s easier to move them around without disturbing anything. Thanks!
I was really hoping this would be addressed in the smoother copy/paste additions released recently. So far, I have not seen it listed nor experienced the ability to reliably bring over the prototype interactions from one page in a file to another file.
Had this problem recently and discovered that it’s very bad practice to prototype master components because they don’t retain their interactions when you copy and paste.
Instead you should always use instances or frames for your interactions and keep your masters separate from the prototype.
Mate, you have no idea how many hours you just saved me. This is brilliant and works exactly how I needed it to! Allow me to turn what you said in a sentence into points so others can scan it quickly when reading this thread:
While in prototype mode (not present mode) do cmd+A cmd+C
Create a new file (not a page in the same document)
Paste everything there
Copy everything from the new file in prototype mode (just like you did in step 1)
Go back to the original file and create a new page
Paste and enjoy the bliss of having retained all of the connections
This works so well for when you have to do multi-lingual prototypes.
So this method does work for the prototype links, however it used to retain the Flow Starting Points and now it doesn’t is there a method that will retain my flow starting points? Please help.
