What is going on with Styles & Libraries
  • February 26, 2024
  • 185 views
I’m trying to determine if I’m insane or if the whole library setup is just crazy bad UX. I have followed every instruction and still can’t get styles to show up. The library I need shows up as linked, but none are available in the “styles & libraries” pop-up. Doesn’t show it as a selectable library. None of the individual styles show up. I can’t understand who this set-up was meant to be better for.
Gayani_S
  • 2145 replies
  • February 28, 2024
Hey @anon50862295, sorry for the issues! I can understand your frustration, I’d would like to help investigate further here why styles are not appearing as expected on your end.
To help to take a closer look, could you please confirm:
  1. Is this issue impacting all files subscribed to your style library or a specific file?
  2. Can you please confirm whether removing and re-adding the style library in the impacted subscribed file helps?
  3. Can you add support-share@figma.com as an Editor to the file where the styles are not appearing and the library file where the styles are defined (this won’t affect your billing at all) and share a copy of the file with me?
Thank you for your help and let me know if you had any follow-up questions!
