Variants -> Moving a variant within its boundaries still takes it out of the variant
  • December 12, 2023
  • 4 replies
  • 441 views
Sanne_Meijer
This is really annoying, I’m decoupling variants without noticing it. It usually happends when I multi select a few variants and move them within the boundaries of the variant component, it will take them out of the mother variant and just make them stand-alone components, without a single hint. I’ll usually notice too late and have to undo alot of work.
Jaydip_Upadhyay
Hey @Sanne_Meijer
I get your point.
To avoid manually adjusting the child component, I recommend adding auto-layout to the mother component.
vice versa, your components did not pop out as stand-alone components.
Sanne_Meijer
Thanks Jaydip, yes I tend to do that, but sometimes I have multiple rows and columns of the variant, and the autolayout doesn’t have the flexibility to break to a new line on a specific count to create such a layout, in this scenario I will usually just disable auto-layout and position manually 🙂
Jaydip_Upadhyay
ohhh understood ✌️
In this case, Figma should include a component lock that prevents individuals from exiting.
Also, it is helpful if they can add an auto-layout option to child components so we can arrange them as a group.
Graham_Paterson
I’ve noticed this generally happens when selecting variants and a layer outside the frame, a label for example. If you do this any movement will decouple the variants.
output
