Variant image would not cha
  • January 16, 2023
  • 8 replies
  • 2446 views
DEStudios
Basically, I am working on an interactive component with variants. I have an instance in which I want to change the image. While the default variant changed, the hover state doesn’t change to the new image applied (it still has the parent component’s image)
  • 4873 replies
  • January 16, 2023
DEStudios
  • 5 replies
  • January 16, 2023
Okay, thank you for this. Case in point, the image on the left is on a master component. On this component, I made the default and hover with the overlay. I saw a video that I followed strictly. It didn’t seem to work.
DEStudios
  • 5 replies
  • January 16, 2023
Please check this out
  • 4873 replies
  • January 16, 2023
I assume that your overlay is not a separate layer, but an additional fill.
Could you share a link to the file? This will allow anyone to see the structure of the component and help to understand the reason.
DEStudios
  • 5 replies
  • January 16, 2023
Yes, you are correct. It is an additional fill. Not a separate layer
Figma – 16 Jan 23
DEStudios
  • 5 replies
  • January 16, 2023
Your comment on it being an additional fill prompted me to make a separate layer instead and it worked just as I intended. You rock!
Thank you very much
Hi, can your share the solution within a Figma file ? Because I still don’t know how you fixed it. 🙂
DEStudios
  • 5 replies
  • March 8, 2023
Hi. Saw this quite late, sorry. I wonder, do you have a fix on it or would you still like me to share a file?
