Unable to edit/delete color library I created as a part of design system
  • September 4, 2023
  • 6393 views
Syed_Uzair_Altaf
Hi,
I created a color library with the naming convention “palette/color”. It was all added fine until I realized I could neither edit the hex codes nor see the hex codes without detaching the instance. Right-click option is also disabled for some reasons. Basically it is acting strange.
Has anyone else faced a similar problem? And if you could please help with resolution, that would be great.
Screenshot 2023-09-04 at 8.42.13 PM
Best answer by MartinBajac
Hey @Syed_Uzair_Altaf ! If you created a group of colors inside the colors style, you can just click outside of the frame and the local styles will show in the tool bar. You can just right click the group and delete the group:
If you created local color variables, you can just click outside the frame, and the local variables icon should be in the tool bar. You can open the local variables and delete the colors you need:
Hope this helps!
MartinBajac
  • 31 replies
  • September 4, 2023
Hope this helps!
Syed_Uzair_Altaf
Hey @MartinBajac,
Many thanks, this solves it. Unknowingly I had created the new color styles under variables and it messed up my brains.
Appreciate your timely help (y)
