Typography Scaling with Shift Key
  • September 23, 2024
  • 34 views
Rahul_Sawant
Hey Figpeeps!
Fledging user here 😅. I am unable to fix this bug/issue with increasing type size using shift. Until now, Figma would automagically increase font size by following a type ramp when I pressed Shift + ↑or↓ (for example 16 would to scale up to 24, 36, 48 etc.)
After reinstalling the program, this scaling isn’t available. The Shift + ↑or↓ ramps by increments of 10 (16 would go up to 26, 36, 46 and so on)
Any idea what’s going on here? Any thoughts & insights are genuinely appreciated. Thank you! 💛
Best answer by Junko3
Hi @Rahul_Sawant, Thanks for reaching out with your question. I totally get why this might be a confusing.
Would you mind taking a moment to check the settings for the “Big nudge” amount? You can find it by following these steps:
  1. Go to Actions/Quick actions
    • UI3: Go to the Tool bar > Click on “Actions”
    • UI2: Figma icon on the top left corner > “Quick actions…”
  2. Search for “Nudge amount”
From what we tested on our end, when I set the “Big nudge” to 10, pressing “Shift” + “↑” increases the text size by 10 (12 > 22 > 32…). Please try adjusting the number to see if there’s any difference.
Also, here are a couple of articles that you might find useful:
I hope that helps clear things up a bit. If I misunderstood anything, please let us know.
Thanks again for getting in touch!
  • Figmate
  • 2179 replies
  • September 24, 2024
Rahul_Sawant
This was exactly it! I browsed over the nudge value earlier, but dismissed the setting thinking it will be about nudging object position vs text values.
Thank you so much for the prompt response!! 💛
