Swapping and configuring instances via setProperties result in weird results
  • October 7, 2023
  • 264 views
Andre_Cassal
I have a component which has different variant as well as boolean and text properties, when I set values via API using instance.setProperties and the object passed changes the variant of the instance
Code example
figma.currentPage.selection[0].setProperties({
    "Text#48:1": "$20.4",
    "Color": "Black",
    "hasSalesPrice": "True",
    "StrikeThrough Text#48:4": "$68"
the problem is that changing the variant and text properties at the same time doesn’t seem to be working.
any thoughts?
  • 4873 replies
  • October 8, 2023
Do you see any errors in the console?
