Swap libraries: the button 'swap library' does not appear
  • October 27, 2022
  • 4 replies
  • 1315 views
Pauline8
Hello!
I would like to create a dark mode to an existing design system. So I wanted to use the feature “Swap library” but when I go the modal ‘Libraries’ and try to swap I don’t have the button 😭
Informations about my files:
=> I have separated files for the design system and the mockups.
=> I have duplicated my light design system to create a dark version.
=> In the files there is styles and components and the exact same numbers and same names.
=> My figma is updated.
=> I have a Pro Plan.
Best answer by Erik_Goens1
I was having the same issue. My issue was that my existing libraries were missing. After connecting the libraries, the swap libraries button showed up.
Screenshot 2023-04-04 at 7.42.39 AM
Jonny5
  • November 25, 2022
Hey @Pauline8 Did you resolve this at all? I’m having the same issue! 🙂
Nolwenn_Sill
Hello !
I have the same issue here.
Erik_Goens1
  • 8 replies
  • April 4, 2023
Robbie_Boyhan
I’m having the same issue. Does anyone have a solution? I noticed that if I click on the library that I want to switch to (i.e. Dark Theme Library), I see the ‘Swap library’ button.
But I’m still not able to select anything in the Choos library dropdown (the dropdown select doesn’t even work).
