Swap images ratio after resizing component
  • February 10, 2021
  • 775 views
Caroline
Hello,
I’m trying to build a component with image on the left and text on the right. I’d like to be able to change the ratio of the image on the left, keeping only its width.
I made several components for each ratio. I can swap the instances without any problems.
The problem comes when i first resize the image component, and then want to change its ratio. Which is the case when the image is in the “image+text” component. Then nothing happens.
I tried to put the component inside a new component, or inside a frame, it didn’t work.
When I use the “auto layout fixed aspect ratio” technique (with 0px objects) it works, but this isn’t workable in our case.
Anyone has an idea how to proceed?
Cheers
Caroline
Be the first to reply!
