SVG path winding order differences
  • August 11, 2022
  • 1418 views
Lee_Murray
Hi!
I am building a plugin that exports svg templates to be used by another tool. The other tool only accepts svg paths with the default fill-rule of “nonzero” to identify subpaths for cutouts & non-filled areas.
I discovered that paths derived from shapes (rect, ellipse, polygon) with outlined strokes generate svg paths with a fill-rule of “evenodd” & all subpaths are drawn/wound in the same direction (counter-clockwise), which is not compatible with the tool.
Paths created with the pen tool, with outlined strokes generate paths with alternating draw/winding directions, which works.
I’d love to be able to export compatible basic paths using outlined shapes, so my question is:
Is there an ability in the plugin API to choose fill-rules or path winding directions, or is this an intentional feature of Figma’s svg generator?
Thanks!
  • August 18, 2023
I have the same question.
Bauke_Schildt
  • January 10, 2024
The Plugin “Fill Rule Editor” lets you change “Even-Odd” to “Non-Zero”:
Figma
Thierry
  • July 13, 2024
I have created a plugin based on the Fill Rule Editor | Figma Community Plugin. I have added the ability to preview and set the first vertex (point) of paths.
Vector Path Editor
https://www.figma.com/community/plugin/1391765568770221941/vector-path-editor
Keep me posted if you have some questions or improvement suggestions. Any advice to make paths more compatible with SF Symbols is welcome.
