Sos. Component instance picture swaps to the original one on hover
  • November 15, 2022
  • 5 replies
  • 2524 views
Mashkinz
I was updating components in the large design file, that has tons of interactive components with overrides, and now, when I hover on my component instance, the picture swaps to the one I have in the original component. It shouldn’t be happening, looks like a bug. It was fine before, but when I updated some visual styles, it start to behave like this.
How can I fix it?
The worse part that I have to present it tomorrow.
Mashkinz
  • 7 replies
  • November 15, 2022
  • 4873 replies
  • November 15, 2022
Sounds like you need to properly assemble your interactive component.
Check out a working example here:
Mashkinz
  • 7 replies
  • November 15, 2022
thanks for your response.
Solution from the link you shared:
I created a base component that only uses a gradient, and then I created a component set based on this base component in which to insert an image. You can test the functionality of the component in your source file.
I did not understand this paragraph. What is a component set? Means instances of the original component?
I had an image inserted in my component. And then I replaced it with other images in the instances. Now it started to pull the “original” image on hover. It actually worked until today, only with some updates I made today it started doing that.
So, it means that I need to have a frame with gradient (?) in the original component, and then insert pictures in the instances?
  • 4873 replies
  • November 16, 2022
I should have been clearer.
Figma Learn - Help Center
As for my example, the image is only added at the “Image Cards” component instance level. And, unfortunately, I don’t know what actions need to be done with your component, because nothing is known about its structure.
  • December 16, 2022
