Slides "appearance" design controls periodically disappear
  • August 24, 2024
  • 5 replies
  • 400 views
Brian_Saunders
I have noticed that, when I’m in design mode, certain settings that normally appear in the right-hand design panel sometimes disappear. It seemed random at first, but today I realized that it’s consistently happening whenever I toggle over to the animation panel and come back to the design panel. Specifically, my corner radius and opacity settings are disappearing. The only way I’ve found to get them back is to right click and refresh the whole file tab.
The attached images show a comparison of the panel before and after I change the slide’s animation settings. You can see that the “Appearance” tools have disappeared. Has anyone else encountered this? I also filed a bug report.
Best answer by y_toku
Hi @Brian_Saunders,
Thanks for waiting! Our product team has confirmed that the issue was not intended, and they have now fixed it.
In my environment, the Appearance section is back to normal. Could you please check if everything is working fine on your end?
Thanks!
  • 2545 replies
  • August 27, 2024
Thanks for reaching out. I’m checking with our internal team. I will get back to you when I have anything I can share with you.
Thanks for your patience.
  • 2545 replies
  • August 29, 2024
Hi @Brian_Saunders,
Thanks!
Brian_Saunders
  • 135 replies
  • August 29, 2024
Hey it seems to be fixed on my end now. Thanks so much @y_toku for quickly elevating this to the team and thanks to everyone who fixed it!
  • 2545 replies
  • September 4, 2024
Thanks for flagging this issue. Please feel free to post when you see other issues!
Thanks again.
nomi_sum
  • 6 replies
  • October 18, 2024
I still have the same issue. Appearance panel is missing again and again on frames and components and only shows up again after refresh.
