Shape Builder Tool
Luke_Caddy
The lack of a Shape Builder Tool (like in Adobe Illustrator) is surprising. This is an essential tool that I use on every project in Illustrator. I have used the Boolean Groups, but they don’t fill the use of a Shape Builder Tool. A SBT allows me to trim the edges of overhanging shapes, which I commonly do when designing.
Sam_Hamilton
  1. I’ve found it to be very unintuitive to create quick unique shapes in Figma. They have a set of predefined masking buttons, but nothing as flexible and easy to use as Illustrator’s Shape Builder.
  2. In Illustrator, there is a tool that allows you to combine or subtract space from overlapping shapes in order to build new shapes quickly. This makes creating icons extremely simple and fast. In Figma, every time I have to create a unique shape, I find myself fumbling through the (in my opinion obtuse) masking buttons to try to figure out how to get it to create the shape I need, and then it seems to retain the original shapes behind the mask, rather than creating new paths and a new bounding box for the new shape. It’s annoying.
  3. Does anyone else miss using the Shape Builder tool, or struggle with the current masking buttons?
Figma_Bot
This tool is the reason why I still use Illustrator beside Figma, to do things like drawing icons,… It doesn’t feel so freedom to doing vectors in Figma. The “Shape Builder Tool” of Illustrator is so good, makes you feel you can create any shapes you want. I like “Vector networks” feature of Figma but it’s just not that good.
Denin_Paul
Shape Builder for Figma 🚀 🚀
Andrew_Designer
The absence of this tool simply forces you to work in illustrator on building anything, more complicated than a primitive, and then import this vector into a figma.
If it wasn’t for the pretty visuals and the “blur background” effect, I would never have even opened Figma.
Adnan_Haj_Ali
we need this tool to move totally from illustrator!
maksimpetshak
Присоединяюсь! И правда, shape builder tool — ОООЧЕНЬ важный инструмент и почему его ещё нет в Figma, для меня удивление, грусть и печаль… Сделайте его пожалуйста в ближайшем обновлении!
Rei_Supercatt
I wish there was an easier way to add/subtract shapes together similar to Illustrator’s Shape builder tool. It would especially be useful for when you’re working with more than just two shapes. The Boolean tools are pretty limiting.
helpx.adobe.com
Currently, I would have to merge the shapes (command+e) and then individually edit the vector paths, which is pretty slow.
  • February 2, 2023
This is absolutely the main reason why we are not committed to Figma and most likely won’t choose it.
Dogukan_Yazici
Still waiting…
zoltanlazar_unas
Seriously, implementing a shape building would make Illustrator obsolete.
  • December 27, 2023
Shape Builder Tool Plugin
Figma
  • December 27, 2023
Pretty good ❤️
Tuva_Persson
I would probably use Figma exclusively if the shape builder tool was available. The only reason why I still use Illustrator at times.
