Save frames as .fig
  • February 17, 2023
  • 7 replies
  • 2266 views
Hi guys, I have a Figma file with 100s of frames and I would like to export each frame as a .fig file. But Figma only allows to save the whole file as .fig.
Do you know a way to easily split each frame into different .fig files?
  • 4710 replies
  • February 17, 2023
This isn’t possible. Why do you want that?
I have a component library and I want people to be able to download components one by one. But their is 2000 components and I don’t want to create manually 2000 files…
why the pdf file is automatically saving when I’m saving a local copy of .fig file…How can I resolve this?
Can anyone know?
AddWeb_Solution
Hello,
Your pc have set it as default that It will show pdf format of .fig file. When you want to open the .fig file, then you can import the file in figma and it will open it as figma file(editable).
Biswajit_Pattanaik
Any solution for this issue? Would love to discuss that!
dennsi
  • 257 replies
  • February 15, 2024
Why though? That is a weird use case.
If you want to have better control on which components you publish into a library, you can exclude components by adding a dot infront of their name.
Example:
.Test-Component_A would not show up in the Publish library window and would be excluded.
Test-Component_B would show up and can be published.
Tipton-king_Jonathan
I agree per frame seems like a weird use case, but it would be nice to at least be able to save individual pages as separate .fig files as my team uses individual pages for different projects that relate to a single page or product.
