Running a prototype changes font weight!
_SD_Miguel_Prado
When I design a presentation on Figma (as a prototype), I add the correct weight for each font (Regular, Medium, Bold, Italic) - when I present it, some of the texts’ font weight revert to Regular.
Does anyone else have a similar issue? Know of any solutions so that the font weight won’t change when running a protoype? Thanks 🙂
Gayani_S
  • 2168 replies
  • May 16, 2024
Hey @_SD_Miguel_Prado, thank you for reaching out!
Please answer me the question below, I need further information on you issue to investigate.
Is this happening in the desktop app and in the browser?
Could you try viewing this prototype in full Present mode rather than Preview to see if this changes anything for you?
Could you confirm if you’ve installed a custom font?
Also are you seeing any missing font warnings?
Are you using variables for your prototype?
Are you able to share a screen recording and if possible your file with me? Please invite support-share@figma.com with “can edit” permission so I can look into this further. Note that users with @figma.com emails on your team do not count towards your billing.
Thanks in advance!
_SD_Miguel_Prado
Hi @Gayani_S, thank you for your reply!
This has only happened to me on desktop, not browser.
I can confirm this issue appears when in Present mode.
It is indeed an installed custom font, though I have made sure to have all the variations properly downloaded. (No font warnings)
Though I am using components on this prototype, the issue appears on specific texts outside the components.
Sadly, I cannot share the file, since it’s work-related (confidential).
Best
Gayani_S
  • 2168 replies
  • May 17, 2024
Hey @_SD_Miguel_Prado, thanks for confirming this!
Let me double check this with our technical quality team. I will get back to you as soon as possible. Appreciate your patience in the meantime!
Gayani_S
  • 2168 replies
  • June 11, 2024
Hey! Could you please check if the same issue happens when you use one of the Google fonts in Figma rather than your custom fonts?
I’ve just created a support ticket on your behalf. Your ticket number is #1024342, for reference.
Please download Figma desktop app debug logs and share it with the support team.
Support should be in touch with you soon.
Our support team usually takes up to 24 hours to reply back to emails - tends to be quicker than that in normal circumstances. However, please be aware that we are facing increased contact volume so there might be a delay.
Let me know if there is anything else I can assist with.
Gayani
Xinyue_Guo
Hey there, I am encountering the same issue. Is there an update on this?
Gayani_S
  • 2168 replies
  • October 24, 2024
Hey @Xinyue_Guo, thanks for reaching out! I understand how frustrating this issue must be, especially when it’s impacting your prototypes.
I checked the previous support ticket, but unfortunately, the other user didn’t follow up, so we’re still missing some information. To help get a clearer picture of what’s happening on your end, could you please share a bit more info?
  • Is this happening in both the desktop app and the browser?
  • Have you tried clearing your cache? Here are the steps for the desktop app: Clearing Cache Instructions.
  • Could you try viewing the prototype in full Present mode (instead of Preview) to see if that changes anything?
  • Have you installed any custom fonts, and are you seeing any missing font warnings?
  • Are you using variables for your prototype?
If possible, it would be really helpful if you could share a screen recording of the issue as well.
Lisa_Morellini
I have this issue too.
  • Happening in both desktop and browser
  • In full present mode
  • I’m using custom fonts (but have been for years and never had this issue). No missing fonts warnings.
  • It is occurring more reliably on the strings where I am pulling in text variables. But it also sometimes happens on strings where I am not.
  • I quit Figma, and reopened it, and that solved the issue of the non-variable strings, but it’s still happening to the variable ones. As soon as I then scroll horizontally on the component with the non-variable strings, they then swap to bold.
  • I cleared the cache as per the instructions, and it’s still happening
It could have something to do with scrollable areas. The variable strings which I consistently see the issue on are hidden within a scrollable area and I have to scroll to reveal them. I moved them up the page so they were visible. They were then not bold, and became bold on scroll.
I was using design system styles, and bold variable on the text. But when I detach those, it still occurs.
I hope this info helps.
Lisa_Morellini
Update: I’ve found completely detaching the string from font style variables solves it. (So not only the weight, but the family)
This has been an incredibly annoying workaround in order to get my prototype to look right. I really hope this is resolved quickly.
Gayani_S
  • 2168 replies
  • October 25, 2024
Hey @Lisa_Morellini, thanks for sharing these detailed steps and for working through the troubleshooting—sounds like it’s been a frustrating process.
I’m glad you found a workaround, though I can see how inconvenient it must be to detach styles just to get your prototype looking right. I’ve gone ahead and created a support ticket (#1160071) for you so our team can investigate this further and look for a more permanent fix.
Our team usually replies within 24 hours, but response times might be a bit longer than usual due to high volume.
I appreciate your patience, and we’ll do our best to get this resolved quickly!
Janne_T
  • October 28, 2024
  • Happening in both desktop app and browser in prototype mode
  • I’ve quit Figma, and reopened it, and that solves nothing. As soon as I open the layout in Prototype mode, both bold and regular fonts change to italic
What bothers me most is:
even the smartest prototypes, components, layouts and flows are completely ignored if and when the public’s attention is only focused on the fact that everything is in italics.
And the poor designer seems worryingly incompetent in the eyes of his audience
even though the reason for all italics is the software.
Lisa_Morellini
I’d prefer to not have an individual support ticket for this, as it appears to be a common bug. I would just like to know when it is resolved.
Gayani_S
  • 2168 replies
  • October 30, 2024
Hi @Janne_T,
Thank you for providing these detailed insights— I completely understand how frustrating it must be to have your design vision compromised by unexpected font changes.
I’ve created a support ticket for you, #1163542, so our team can investigate what might be causing this issue.
Typically, our support team replies within 24 hours, though there may be a slight delay due to increased contact volume right now. We’ll do everything we can to get this resolved quickly.
Thank you for your patience!
Gayani_S
  • 2168 replies
  • October 30, 2024
Hi @Lisa_Morellini, thank you for sharing your thoughts—I completely understand preferring not to open individual support tickets when an issue seems widespread. However, to help our team confirm the specifics of this bug and work toward a resolution, they do need additional details from you. I checked your ticket (#1160071), and it appears they’re awaiting some follow-up information to dig deeper into this issue.
While we recognize this may be affecting multiple users, your insights could really help the team pinpoint the cause more effectively. If you’re able to provide the requested details, it’ll be a big step toward resolving this for everyone experiencing it.
Thank you again for your patience and cooperation as we work through this!
Juaniz_Fernandez_Juncal
Hi! I’ve got the same problem, when I run my prototype the weigth of my fonts change to bold. Is this problem been taking care of?
Veniamin_Mylnikov
same problem, where is solution?
Gayani_S
  • 2168 replies
  • November 26, 2024
Hey everyone! I’d love to help get to the bottom of this. None of the previous users experiencing this issue followed up on their support tickets, so we’re still missing some key details to fully understand what might be causing it.
It would be really helpful if you could provide more information about what’s happening on your end:
  • Does this happen in both the desktop app and the browser, or just one?
  • Have you tried clearing the cache? This can sometimes resolve unexpected issues.
  • When running your prototype, does switching to full Present mode (instead of Preview) make any difference?
  • Are you using any custom fonts, and if so, do you see any missing font warnings?
  • Are variables being used in your prototype?
If possible, sharing a screen recording of what you’re experiencing would be really helpful for us to investigate further.
Monika Pawlak
  • clearing cache in dev tools and refreshing has worked for me but just temporarily. next time i go to prototype link, it’s all bolded again
  • happens in browser
  • no difference if full screen or preview mode
  • we use custom fonts, but no warnings
  • we use font variables
Gayani_S
  • 2168 replies
  • January 29, 2025
Hey ​@Monika Pawlak, thank you for trying out these troubleshooting steps!
To help narrow this down, could you try testing the prototype in a different browser? Figma supports Chrome, Firefox, Safari, and Edge, so it’d be helpful to see if the issue persists across multiple browsers. If possible, could you also check if the same thing happens in the desktop app?
If the problem continues, I can escalate this to our technical quality team to take a closer look. Let me know what you find, and I’ll be happy to help further!
Ben08
  • March 4, 2025
Hi,
I'm experiencing the same issue on the desktop app. Sometimes, I can fix it by duplicating my frame and deleting the old one, but it doesn't always work. Additionally, if it occasionally fixes the issue, but I open the slideshow (desktop app) from another computer, the problem persists on that machine.
Ben08
  • March 9, 2025
Hello ​@Gayani_S any update on this issue ?
Dennis_Harz
  • April 28, 2025
Hi,
we had this issue in 3 separate prototypes at my company recently. The prototypes are running fine unless viewed in Incognito Mode or during live tests with users (super professional).
At certain inconsistent points the message ‘missing fonts replaced’ will show up and then the prototype breaks. This can be something benign like a regular font weight instead of bold, but it will also fail to render text entirely (the autolayout compensates, so the text literally isn’t there).
We noticed that this issue could be reproduced when we triggered some visibility changes via toggles. Repeating hide/show (as in filtering a list and toggling a boolean on certain elements) will eventually cause the issue. Sometimes immediately, sometimes after a few iterations.
As the fonts get loaded correctly initially, we assume that loading in custom fonts during runtime of the prototype is causing issues. Does Figma forget things when elements are hidden and tries to recover from faulty caching, is it a network issue when trying to reload custom fonts, does showing previously hidden objects re-render these differently than during the initial load? - we don’t know.
For now, we replaced all fonts with a Google font and the problem seems to be resolved. I couldn’t reproduce the bugs anymore, but this is NOT a solution. We can’t be testing UIs with some Google font just to appease Figma, not to speak of the man-hours we sank into fixing this.
