Rotate Text 90 Degrees
David_John_Turton
Can text inside a shape be rotated 90 degrees?
Best answer by Matthew_Cui
Select the item boxed in red and type in “90”
Matthew_Cui
  • November 8, 2023
Hi @Matthew_Cui your screen is from Figma. Question is about “FigJam”
I’m also searching answer for this question. Probably FigJam don’t have this option
dvaliao
  • 4635 replies
  • November 8, 2023
Hey @Jaz_Bek, thanks for pointing that out!
In FigJam, while you can’t rotate the automated text applied to a shape, you can leave a shape blank then add a separate Text string on top of the shape and rotate that by hovering near a corner until the rotation arrow appears.
