Resizing a vector proportionally
  • April 25, 2023
  • 5462 views
Cian
Hi all,
This is probably super basic but I’m really new here and learning all the time, well at least trying.
I’ve made a vector image of a helicopter and some clouds but when I try increase the size the lines remain the same thickness which results in a chunky heli if reducing size or a skinny one it increasing size. How can I resize but the proportions remain the same?
Best answer by Celine_
Hi @Cian,
You can proportionally resize your layers and objects by using the scale tool.
This tool preserves aspect ratios and ignores constraints of any nested layers in order to scale them proportionally. Any blurs or strokes will scale as well.
For more information, you can check our Help Center article to resize an object using the scale tool: here
Hope it helps!
Celine_
  • April 26, 2023
Hi @Cian,
Hope it helps!
Cian
  • April 26, 2023
Hi Celine,
That worked perfectly, thank you so much.
Cian
