Reset scroll position of an overlay when closing
Hi all,
I’ve been running into a scroll position issue since state management was introduced.
I have a page with various buttons, and when selected, opens an overlay. These overlays have scrollable content on them, allowing the user to view the content. If the content has been scrolled and the overlay closed, when reopening the overlay the scroll position hasn’t been reset.
I have the option to ‘reset scroll position’ on the button-to-overlay interaction, but this resets the main page and there is no 'reset scroll position on the ‘close overlay’ menu interaction.
I ran a test there the overlay was treated as a new page (so ‘navigate to’ instead of ‘open overlay’) and the ‘back’ interaction on the overlay has the option to reset and behaves as expected.
What am I doing wrong? I know the state management setup indicates that layers need to be named the same, but this is to maintain scroll position. I need to reset the scroll position on the overlay once it has been closed.
Thanks
Hi all, I have the same problem in my overlay and would like to learn a solution for this.
Many thanks
Marcus_Harvey
  • 10 replies
  • September 14, 2023
I have the same issue
Same issue here. When “open overlay” is selected as an interaction, the overlay does not reset scroll position even if I have selected “reset component state”. This has worked previously and doesn’t.
Does anyone know solution to this issue?
Viktor_Lanneld
Same problem here. Would be easy to have an “Reset scroll position” option as for other interactions and keep the default to not reset it.
Lachlan1
  • 15 replies
  • October 25, 2024
Same issue here. This is wreaking havoc on our prototypes for usability testing and really starting to test our patience. I honestly can’t think of a reason why i’d want to reset the scroll position of the page when opening an overlay so this reeeeallly feels like a bug.
philoup
  • October 31, 2024
I have the exact same issue and would love to know if there is a solution or workaround!
Emre1
  • November 8, 2024
Same problem here… just a checkbox for reset would be enough i guess
Fernandes
  • November 18, 2024
Same issue here. A year later, there is still no solution?
Markus Sørem
I have the same issue. Very annoying when making prototypes for user testing..
Madalayne_Rockarts
Having the same issue! Hopefully someone has some answers.
Jon_Dean
  • July 2, 2025
Same issue. Figma please replay with a recommendation.
JP112
  • 4 replies
  • July 2, 2025
Hey All,
My guess is that you could create a Variant set up with your overlay. One state with your overlay content and another state would be blank & transparent or what ever. When you set up your “Click” to close the overlay, also set up a “Change to” to change the overlay variant to the blank state. When you do this you can also reset the scroll state on the inital Overlay state. Then add a “Delay” on the blank state to “Change to” the original state.
Let me know if it works :)
JP
JP112
  • 4 replies
  • July 2, 2025
I just tested out my suggestion above and it works like a charm.
