Remove figma website & project link in a prototype embed
  • March 27, 2023
  • 13 replies
  • 4735 views
Hi I have a prototype that I would like to embed to a website, my question is it possible to remove or disable the figma / project links at the top & bottom of the embed?
Best answer by tank666
  • March 27, 2023
  • October 31, 2023
is doesnt work anymore is there any alternative available?
  • October 31, 2023
Sorry, I can’t confirm this. I just tested this on my end and everything works as expected.
  • October 31, 2023
Doesn’t work for me either, stopped working after a page refresh. It was working for me before.
  • October 31, 2023
Could you show the embed code?
  • November 1, 2023
interesting… it seems to be working again for now. I’d prefer not to share embed as it contains some sensitive information. I had tried both methods above but the only one that works for me is adding “%26hide-ui%3D1” to the end of the URL. Thanks for the response
  • December 29, 2023
May I ask what does %26hide-ui%3D1 means?
  • December 29, 2023
@Sabrina10,
Zack_Lewis
  • January 26, 2024
This is awesome. Thanks so much for sharing @tank666!
Without going through the major hassle of using a personal access token and fetching the nodes for each image, etc. and then displaying them accordingly on a site… is there any simple way to show a Figma image on a website and if you change that Figma image, it then changes on the website (without the canvas/UI elements…JUST the image itself).
None of the above work as I’ve tried all of them. The only way I could do it is with quite a bit of custom code because it seems they do store images on AWS for example: https://figma-alpha-api.s3.us-west-2.amazonaws.com/images/5bf61610-63d2-4ae6-8b75-2626d85504fc but I want to be able to ALTER that image and keep the same URL which doesn’t seem to be easily done unless you do something like this coupled with HTML that corresponds:
// Your Figma File ID
const fileId = ‘XXXXXXXXXXXXX’;
// Your Personal Access Token
const personalAccessToken = 'figd_X’XXXXXXXXXXXXXXXXXXX;
// An array of node IDs for the specific frames or objects you want to get the images for
const nodeIds = [‘65:3’, ‘75:14’]; // Add more node IDs as needed
// Fetch the image URLs from Figma for multiple nodes
async function fetchImagesFromFigma() {
const url = https://api.figma.com/v1/images/${fileId}?ids=${nodeIds.join(',')}&format=png;
try {
const response = await fetch(url, {
method: ‘GET’,
headers: {
‘X-Figma-Token’: personalAccessToken
if (!response.ok) {
  throw new Error(`Failed to fetch images from Figma (status ${response.status})`);
const data = await response.json();
// Assuming you want to embed the images in <img> tags with IDs corresponding to node IDs
nodeIds.forEach(nodeId => {
  if (data.images && data.images[nodeId]) {
    document.getElementById(nodeId).src = data.images[nodeId];
  } else {
    console.error(`Image not found for node ID ${nodeId} in response data:`, data);
} catch (error) {
console.error(‘Error fetching images from Figma:’, error);
// Call the function to fetch and display the images
fetchImagesFromFigma();
  • September 25, 2024
This is great! Thanks so much for this!! 🙂
S_G1
  • April 11, 2025
I’m trying this but it’s not working :/
James Hart
  • May 15, 2025
Add:
&hide-ui=1
At the end ofyour project link
