Relink instances to duplicated components from a new file
  • August 30, 2022
  • 5 replies
  • 3839 views
Karim_M
Hi!
Here is my situation : I have duplicated my design system file and my main design file. By doing this, my duplicated design system has components still linked to the original main design file.
I have no idea how can I relink my new instances to my new duplicated components. Any idea, plugins?
Best answer by Gleb
It can be done much easier: Swap style and component libraries - YouTube
Amalya_Henderson
If I understand this correctly, you should be able to go to your new instances and manually swap instances in the right panel to point to the Local Components version instead of your original file’s component. You may be able to do this faster by using the Select All with Same Instance or with Same Variant options in the Edit menu for some quick multiple instance/variant edits.
Karim_M
  • 5 replies
  • September 1, 2022
Waow… I completely forgot I can do that! Thank you very much.
It’s not really in the local file I want to reconnect, but I can do this way even if I want to reconnect to a new file.
I tried a plugin but it’s not working that good. Just in case someone seeing this, it’s called “Component Relinker”.
Thank you again Amalya. 😃
  • 4710 replies
  • September 1, 2022
Karim_M
  • 5 replies
  • September 1, 2022
😭 😭 😭 😭 😭 It was really that simple??? Thank you Gleb, that’s exactly what I was looking for. It’s been 3 days I am looking for this ahah.
I’ll tell you if it works, the publishing is a little bit long.
Karim_M
  • 5 replies
  • September 1, 2022
It’s seems it worked but the alert was stucked at a certain amount of connections. By clicking on the alert it disapeared so I don’t really if everything is connected now. I will try this way. Thank you guys !
