Edward_Roumoulian
Jun 21, 2023 8:28 AM UTC
Prototyping with transparent videos
Whatever I try, I can’t seem to work with .mov or .webm videos with transparent background on Figma. Whenever I upload them, I get a black background. Am I doing something wrong? Or is there a workaround for this?
James_Piper
Jun 26, 2023 10:47 AM UTC
Did you figure out a solution for this? I’ve got the same issue
Edward_Roumoulian
Jun 27, 2023 7:38 AM UTC
Nope. I did a workaround, put the website background in the video. Not ideal since every time you change the website, you should edit the video too, but it helps with visualizing.
Mario_Barbosa
Jun 27, 2023 3:10 PM UTC
Seems to be a bug, as I imported a .webm video with a transparent background, and when running the prototype, it appeared perfectly without the background. But then after repositioning, and resizing, when opening the prototype again the black background appeared. And even running Ctrl+Z, for the previous position and size, the prototype continued to show the black background.
Jul 10, 2023 5:21 PM UTC
Did anyone find a solution for this?? it’s soooo annoying…
Global_Wizards
Jul 19, 2023 3:34 AM UTC
sera el que problema persiste?
Jouni
Jul 21, 2023 1:36 PM UTC
Also seeing this issue - webm with transparency is very buggy. Shows the first time and never again after that in prototyping mode - black background.
Please fix!
Dmitry_Avrov
Aug 2, 2023 9:10 AM UTC
Same problem! Please fix.
Mietkiewicz_Hubert
Aug 2, 2023 11:31 AM UTC
Yep, same problem. We really need this one, please help.
Charlie16
Aug 8, 2023 8:06 AM UTC
Ditto! This is a NEEDED feature. Please assist!
Mudita
Aug 9, 2023 4:11 AM UTC
Had the same issue, ended up converting it to a GIF instead
