PROTOTYPING absolute position and auto layout
  • July 23, 2023
  • 6 replies
  • 1330 views
Natalie_Myers
I’m fairly new to Figma and I’m not sure how to even search this to find answers, I’m trying to prototype a desktop website. I want a horizontal list of cards that when you click on them, more information shows below them. I am trying to make it like an accordion type card where the information is hidden in the default component and shown in the variant component.
EDIT: “new users can only put one media” Im going to comment the rest of the images
the first image shows how they’re all in a line, the second is a successful pop out. the third image shows how step 2 is not sitting right within the frame/auto layout. the 4th and 5th images are my wip components. Does this make sense? Does anyone know how to have the step 2 sit in line with the rest of the cards and have the information pop out below?
Best answer by Haroll
Hi @Natalie_Myers,
Auto layout and absolute position might not be the best way to resolve your problem : Going that way, you will need to specify every gap between your cards and the left side of the page. If you ever change the page width, padding or such you will have to define those gap again. This is you doing the heavy lifting instead of Figma.
An easier solution would be having 3 components :
  1. Card component,
  2. Information component,
  3. Card + Information component
The information component
One variant = one description. (In your case you should have 5)
The card + information component
The card + information is built has a vertical auto layout with two main space:
  1. the first one is an horizontal auto layout of card instance,
  2. the second one is an instance of the component: information
(for this component to be responsive, nested instances and auto-layout frame have to be their width set to fill)
It has only 1 property, allowing it to changes the information displayed (as shown below)
This way the information panel will always use the same space and be left-aligned.
Let me know if it helped!
Natalie_Myers
Natalie_Myers
Natalie_Myers
Natalie_Myers
Screen Shot 2023-07-23 at 7.43.10 PM
Haroll
  • July 24, 2023
Hi @Natalie_Myers,
  1. Card component,
Natalie_Myers
Thank you so much that worked perfectly !!
