Prototype is a throwback
  • September 2, 2024
  • 13 views
shirieda
If I update the original main component after setting a prototype for a component, all the animations etc. set in the prototype will disappear. Could you please tell me the solution?
Example: Let’s say I was creating a modal component. Let’s say I have a complicated setting where when I tap a button, a message saying “Sending completed” appears, and then I return to the top screen. Then I resized and updated the buttons in the main component of the modal. Then all the settings I had made up to that point are gone and I have to start over again.
  • September 2, 2024
Thanks for reaching out! Since I haven’t reviewed the file, my response will be quite general. Typically, we recommend not using components directly in the prototype. Instead, it’s better to use instances of those components.
I see you’ve already contacted our support team, which is great! Please continue working with them, and they will help you resolve the issue.
Toku / とく
