Prototype "Back" is not working in my prototype somehow
James_Chung
Hi Guys, i was create the “back” interaction. I set up as “tap” + “back” on an arrow. However, when i present, it doesnt go back to the previous screen. It seems like there is no interaction exist at the arrow.
May i know if the above set up is correct? Do i need to do extra links or set up in order for the arrow to work as “back” ?
Thank you!
Best answer by Marketa_Konecna
Hi, I had the same problem. I went back to design interface and in “stroke” area I changed from “inside” to “outside”. Now it is working. Hope it will be helpfull. 🙂
Jaz
  • September 25, 2021
Same here! Did you get any feedback?
James_Chung
  • September 26, 2021
Hi, didn receive feedback but what i did was just copy and paste all the frames, and it works on the new one.
Stefan_Csincsik
Same here. Back is not working
Imke_Heymann
I’m having the same problem. I’m iterating on my first prototype but the back is not working. Did you find a solution?
Stefan_Csincsik
Nope, I set fallbacks manually to the previous screen, which is currently the most suitable solution IMHO.
Marketa_Konecna
Amar
  • February 22, 2022
It works! Thanks!
Alex_Gerhardt
Thank you!
heera_nasar
yes it works. Thanks a lot
Amirreza_Tavakol
Thank you!
Nikhil_Ghinmine
thank you it works
ganiu_olamilekan
Thanks it works
Chloe_Webb
Thanks it worked for me as well!
Riya_Vishwakarma
thanks <3 this helped
Richard_Dante
Back button don’t work when you are using “Overlay”
Femi_Loto
thanks, this works
Ahmed_Elmorsy
Thanks, it worked
nspgid
  • November 21, 2022
Thanks, it works.
Johnathon_Niles-Humphrey
Thank you so much, this helped a lot and all of my arrows are working. Do you now why this happens?
Thank you so much! Worked for me as well!
  • July 24, 2023
Thank you so much!
omg! this worked for me. Thank you so much!!!
OMG you are a saviour! I have been trying so hard for the past 24 hrs … posted this question on random youtube videos and your trick worked. Thanks a tonn!
It worked!! Thank you
Tyrone1
  • March 24, 2024
Just a little addition here since I found myself coming back to this thread for the same issue again. The first time I had this issue, setting the stroke to ‘outside’ seems to have worked. However in a second version of my project I couldn’t get it to work properly again.
My solution was to simply expand the height of the frame the arrow was in and center the arrow in it. I think the issue was that because the arrow was just a stroke with a height value of ‘0’ (the arrow pointer is just a “decoration” to the stroke), the frame also had a height of ‘0’ which made it impossible to click. I changed the frame height to ‘15’ in my example and it worked fine with no other changes.
I’m not 100% sure my theory on why it wasn’t working is correct, but fixing the frame height did solve my issue.
If I’m correct in my assumption about the 0-value height, then flattening the arrow to make it a vector shape should also fix the frame height to the full height of the shape, at the expense of losing some editability.
