Proplem in auto layout
  • February 2, 2024
  • 146 views
I wanted to know a solution to a specific problem in Figma. When I select two layers and press shift+a, the two layers separate from each other, which forced me to reduce the size of the gap, and the lower two layers flip over and vice versa. I replaced the account with another account, but the same problem is not solved. So, is there a way or do I contact the site’s technical support to fix the problem? ?
Now I am suffering from this problem and I do not know how to solve it. I had to make a group and then auto layout, but it did not work for me. I also do select frame twice and then auto layout, but this is very tiring, especially if the project is large.
Raphael_M
  • 394 replies
  • February 3, 2024
Hi.
Is it possible for you to describe more about your problem with videos?
Thanks
