It would be great if we could put the properties in the order we want in the variants.
With drag and drop like layers.
Have a good day
Have a good day
You can change the order of properties and property values.
https://help.figma.com/hc/en-us/articles/360056440594-Create-and-use-variants#Reorder_properties_and_values
How do you change the order of the variants within the properties?
Eg.
to Size: S, M, L, XL
UPDATE - I see that you can drag the pills around (that wasn’t obvious - but it works)
Thank you! This helped. The original solution was changed in an update, apparently.
OMG I am sooo glad to have found this out! It’s been driving my OCD nuts It wasn’t easy to find.
I created 23 properties to easily edit a table (one property for each text), but when I copy the component to use, was without the order planned and I don’t know how can I fix that
